Home > Maintenance & Mods (L322) > RANGE ROVER L322 2012 Rear Differential Plugs part number ?? |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
Try here, it may be helpful
28th Nov 2022 5:48pm |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 123 |
Yep, been there already, but "2002 to 2012" is a long stretch and the part number are again different from the ones I mentionned ...
28th Nov 2022 8:17pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Send Duckworths or LRparts.net an email, either will be able to tell you the correct part numbers (and sell you the parts) from your VIN. |
28th Nov 2022 9:21pm |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 165 |
On my 2009 3.6TDV8, standard rear diff, not the e-diff. Landrover parts.
28th Nov 2022 9:48pm |
Actually, it's reasonably easy to find out from here
28th Nov 2022 10:22pm |
Thanks Phoenix,
29th Nov 2022 1:33pm |
It appears so, clearly the drain was a different p/n but was superceded. I can find no reference to anything other than that part number for both the drain and fill plugs.
29th Nov 2022 4:11pm |
I'm off for a buying spree then !
29th Nov 2022 4:57pm |
