Home > Maintenance & Mods (L322) > My Hella Rallye 3003 LED setup.
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Hello All,
In a couple of weeks I'll be going North again, through Sweden and Finland into Norway.
This time of year it will be dark there a lot of the time so one needs extra light, lots of extra light.
In fact, one can not have enough extra lights Cool
Having used Hella LED lightbars last year I decided to go for the 'Kiruna Kit', as they call it in Sweden.
2X Hella Rallye 3003 LED, ref 50 (and one LED lightbar from last year)
This is how it looks from inside the car.
(I have to say it doesn't show the extra light too well in the pictures)
OEM Normal Beam
OEM High beam
This is with 2 year old Philips RacingVision GT200 as high beam, they did make a difference.
The Kiruna Kit
Up north, in the snow, it will look better.
They also need to be fine adjusted to get the spot where you want / need it.
One really needs to see it on the road, a small change at the lights can make a lot of difference at 400-500 meters.
Front View
The brackets
The wires are not as nicely ty-rapped as they will be, this was the final test fit.
Adjuster bracket
The slot should give enough freedom for adjustment.
In Sweden I saw cars with a left/right thread adjuster, I looked on ebay but could not really find what I liked.
So I made these brackets.
Last year I installed an extra relay (40A), powered by the high beam wire of the drivers' side headlight cable loom, via a dashboard switch so all the extra lights need the high beam to be on and the extra switch.
Still, with ref 50, these lights would be illegal to run with any of the OEM lights as one can only have up to ref 100 of light on a car.
In Sweden, and especially up north, no one cares though.
They understand you want to see as far as possible to avoid hitting reindeer or elk.
Even with spiked tires, on ice and compact snow the braking distance in much much longer.
Comments appreciated Very Happy 2012 4.4TDV8
2000 Honda S2000
Post #649277 27th Nov 2022 10:46am
certainly look the business.. Thumbs Up
would a led light bar be better maybe?
something like this in this thread,
https://www.fullfatrr.com/forum/topic42918...t=lightbar
have a safe trip . ... - .- -.
Post #649279 27th Nov 2022 10:50am
SpitfireS
Thanks for the Thumbs Up
The LED bar light spot I found to be too narrow, especially vertically.
Horizontal spot was ok-ish.
The adjustment of the Hella lightbar was also quite difficult.
You have to undo the whole support bracket to be able to rotate it up or down and then everything is so loose you can't really see where it will be when everything is tight again.
The 3003's shine about 200m further.
Cool 2012 4.4TDV8
2000 Honda S2000
Post #649280 27th Nov 2022 10:57am
Phoenix
I've found the light bars great for wide area illumination but not so great at range, the problem with snow is that there is a lot of reflection, so sometimes too much floodlighting can work against you as the glare prevents you seeing what the spotlights are picking up further ahead. Long range spots are great but need setting up carefully, I used Lightforce 240's with the HiD conversion kit, once you have the spot 'ranged in' , you can adjust the reflector to give you anything between full spot to full flood as conditions dictate. I used them for many years from Saharan Africa all the way up to Suomi Finland, The only reason I don't use them now is they were stolen (very carefully) from the front of my car, they managed to leave the HiD ballasts behind though....
Post #649286 27th Nov 2022 3:22pm
SpitfireS
https://i.imgur.com/FhN1ehR.mp4
Here's a short video of how the extra lights perform.
The 3003's could be a bit higher but the bracket doesn't allow it, the slot needs to be bit longer.
But it's ok.
Idea 2012 4.4TDV8
2000 Honda S2000
Post #652065 30th Dec 2022 3:16pm
Phoenix
I'm very impressed with those!
As you say, they need to be slightly higher to improve the range, but not by much. A job for the Dremel when you get home Wink
Unfortunately I don't get as far afield as I used to so the HiD's will have to do for now, I'm thinking of putting some mini LED bars behind the grille to give the high beam flash a bit of 'punch'...
Post #652076 30th Dec 2022 3:41pm
ikjos
Norway 2012 Range Rover Westminster 4.4 V8 Santorini Black
Here in Norway it's nice to be able to light up the road, but just as important also the terrain where there are lots of big animals like deer and moose lurking in the dark. Ready to jump on any incoming drivers.
It's not the best idea to use the roof lights when it's snowing, due to the hypnotizing effect of big white flakes coming straight at your eyes.
Only thing is to remember to dim down early enough to not blow the eyes out of incoming driveres Smile
2012 - L322 Westminster
QRV @ LA2VSA / DA1AA
Post #652152 31st Dec 2022 10:14am
SpitfireS
As I still have another lightbar I'm thinking to put it above the other one and point the two Ralleys a bit more to the edges of the road, to, as ikjos said, be able to spot animals at the side ready to step onto the road.
One can not have too much light!
Btw... ikjos, no spiked tires?
No piggdekk Very Happy
And yes, you basically drive with one hand close to the high beam switch, ready to switch back to normal lights. 2012 4.4TDV8
2000 Honda S2000
Post #652174 31st Dec 2022 1:43pm
