Home > Technical (L322) > cutting out
John-suusex
cutting out
Hi, 08 3.6. 150k mls. Has started cutting out after the first 10 to 15 minutes at times. Turn off and will be fine on a restart. Have a multitude of error messages when this happens, from engine, trans fault, handbrake etc. Once restarted no errors. Not read codes as yet, but a battery test showed a low battery, this has been replace with a new 019 type. Are there any common faults to look at before i can get it to the garage? Getting 14.5 plus volts with running engine. Thanks 2008 TDv8 Vogue in Java black x2
2000 P38 They aren't all bad!
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649224 26th Nov 2022 4:26pm
JayGee
Did this happen before you replaced the battery? 2012 TDV8 Vogue (L322)
Post #649225 26th Nov 2022 4:33pm
John-suusex
Hi, before. The battery was checked and deemed at fault, hence changing it. 2008 TDv8 Vogue in Java black x2
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649226 26th Nov 2022 4:48pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Engine / body earth wires clean connections and sound wires? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #649227 26th Nov 2022 5:12pm
Weegie
Make sure the battery leads are right down on the posts. I have had to tap them down before as they are slightly conical in shape. John
GAP iiD BT
Post #649237 26th Nov 2022 6:35pm
Phoenix
If the concern was evident before changing the battery, then it's not the battery causing it.
What DTC's are you getting?
Post #649238 26th Nov 2022 6:42pm
John-suusex
Not had them read yet, i've not got a reader for this one. decided to leave it to the garage for now. 2008 TDv8 Vogue in Java black x2
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649239 26th Nov 2022 6:48pm
Weegie
Where are you in Sussex? I have a Gap iiD if you are near me and would like the faults read. John
GAP iiD BT
Post #649244 26th Nov 2022 7:46pm
John-suusex
Hi near worthing. Thanks, but dropped off at the garage now. 2008 TDv8 Vogue in Java black x2
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649245 26th Nov 2022 8:03pm
Weegie
Thumbs Up Fingers crossed. John
GAP iiD BT
Post #649248 26th Nov 2022 8:23pm
John-suusex
Well, Garage rang, no further forward, non of there scanners can read the live data they wanted. I still think it's electrical, however they tell me it's fuel fault. Not sure, as many warnings up on the dash. all well 2008 TDv8 Vogue in Java black x2
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649733 3rd Dec 2022 5:13am
gettingold
Take up Weegies offer, can’t do any harm. visiting from www.rrsport.co.uk
Post #649734 3rd Dec 2022 6:56am
John-suusex
was rather hopeing too.. 2008 TDv8 Vogue in Java black x2
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649735 3rd Dec 2022 7:14am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
How does it cut out?. Suddenly or gradually. Suddenly would indicate electrical, gradually would indicate fuel. See how you get on with Weegie Thumbs Up
Post #649744 3rd Dec 2022 9:33am
John-suusex
Suddenly, no warning. 2008 TDv8 Vogue in Java black x2
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649747 3rd Dec 2022 10:06am
