Home > Range Rover P38 > cutting out
John-suusex
cutting out
Hi, 08 3.6. 150k mls. Has started cutting out after the first 10 to 15 minutes at times. Turn off and will be fine on a restart. Have a multitude of error messages when this happens, from engine, trans fault, handbrake etc. Once restarted no errors. Not read codes as yet, but a battery test showed a low battery, this has been replace with a new 019 type. Are there any common faults to look at before i can get it to the garage? Getting 14.5 plus volts with running engine. Thanks 2008 TDv8 Vogue in Java black x2
2006 4.4 Vogue se
2000 P38 They aren't all bad!
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649222 26th Nov 2022 4:24pm
John-suusex
Sorry wrong group... 2008 TDv8 Vogue in Java black x2
2006 4.4 Vogue se
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649223 26th Nov 2022 4:26pm
