![]() | Home > My Range Rover > Shocked L322 owner looking forward |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
I hear the 405 is a great car, but that many that have owned both still feel the L322 is the proper Range Rover of the two, a little more utilitarian and tank like, as per its heritage.
For your budget you will get a good low mile late TDV8 4.4 L322. I'd not buy an L405 for that money unless I had a lot in reserve for repairs. 2012 TDV8 Vogue (L322) |
Davy_db Member Since: 24 Nov 2022 Location: Belfast Posts: 3 ![]() ![]() |
From what I read and gather it does seem to be the proper last rr, I have considered going for a face-lift ab l322 and not ruled out but they are pretty expensive, all mostly still above 100k miles and not sure I want to spend so much for the same shape jeep. I don't plan to be doing any off road trips or such, just the odd bit of towing and more just the luxury drive.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Well, if you buy a higher mile L322 or L405, it will eventually become normal miles if you don’t do that many miles each year. I’ve done less than 3k a year since Covid hit…. In fact I’ve only done about 15k in 6 years.
It’s not a bad idea getting an L405 at all but your budget is a bit too low I think. 2012 TDV8 Vogue (L322) |
I appreciate the honesty, I think I may have to take one a test drive to see if it's going to be worth the stretch, when I say alittle over 20 I probably have 25 and hoping with the way fuel prices etc are the odd one might just come up for good money. Thanks |
Maybe test drive a late L322 TDV8 4.4 as well? 2012 TDV8 Vogue (L322) |
