Home > Maintenance & Mods (L322) > 2008 SC has vibration in driveline. How to identify cause
Gordo51
Canada 2008 Range Rover Supercharged 4.2 SC V8 Barolo Black
My 2008 SC has developed an odd vibration in the driveline. I do not feel anything in the steering wheel, only in the seat bottom. Can also hear a thump, thump as if something is out of balance. Crawled under car once so far and tried wiggling drive shafts and half shafts but nothing moves. Any thoughts on how to proceed to ID the cause? Thanks. Gordon
Post #640923 26th Aug 2022 1:26am
check those rear tyres ...you might have a bulge in one or one of the wheels might be buckled.. ... - .- -.
Post #640927 26th Aug 2022 7:24am
Gordo51
I did have all 4 tires rebalanced and checked for out of round. 2 were out of round and they corrected 1 but could not counturbalance the other.
I don't think this is enough to cause the problem though. Thanks for the reply.
Post #640979 26th Aug 2022 3:31pm
AnotherMutley
You could see if you could hire some chassis ears, helped me once to find an annoying vibration on my old Disco 2. If you haven't seen them before, its 4/6/8 mic's and an amplifier you attach to various points on your car and listen for the noise while driving.
Have checked prop/uv joints/carrier, stuff like that.
Post #640980 26th Aug 2022 3:49pm
Gordo51
Never heard of those chassis ears. I have been under the car once trying to wiggle the drive shaft and half shafts but all seemed tight. I know it can be tricky to get tension off so am going to try again today with wheels off the ground and Trans in neutral. Thanks for the reply
Post #640981 26th Aug 2022 3:53pm
Gordo51
I am going to remove the driveshaft and replace the steady bearing as not very expensive and not too hard to do from what I've read. Will also check or replace the U joint that is ahead of the steady bearing.
Post #641114 27th Aug 2022 5:54pm
Gordo51
Well I installed a new driveshaft for $1k and that did not fix the problem so I had to take it to a nearby LR dealer. They replaced a bunch of rear suspension components and that fixed it. $1500 for parts but they discounted that to $1100. Add $2k for labour and $300 for tax so total was $3400. Not too bad. 202k km on the car. They suggested I replace my steering rack for $5k because it had a leak or some play, got two different reasons, but doing that considering I can buy a rebuilt one for $500.
Happy to get the car back on the road as it is a pleasure to drive.
Post #649065 25th Nov 2022 1:35am
dhallworth
That's a good result.
Annoyingly, mine has developed a slightly vibration over 65mph since doing all my bushes.
I've since found out the 2 rear wheels are slightly out of round so they're going in next week to get sorted so hopefully that'll be the end of it.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #649093 25th Nov 2022 11:59am
Gordo51
One of the first things I tried was getting all 4 wheels re-balanced and checked for out of round. They did find one tire that they could not completely balance out but the tires were not the problem. It took 2 weeks for them to get all the parts they needed. I had to wait 3 weeks before I could even take the car in so all in all I was without the car for 6 weeks. Luckily I have a reliable P38 to drive around.
Post #649122 25th Nov 2022 4:41pm
Classic888
Possibly a sticking rear brake caliper
Post #649287 27th Nov 2022 3:38pm
dhallworth
I did wonder about that but there’s zero heat in the back wheels after a long motorway run. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #649291 27th Nov 2022 4:15pm
Gordo51
The dealer did say my left rear caliper was sticking and that could cause a vibration but turned out to not be the problem. It does seem to be sticking to some extent as that disc is much hotter than right rear. Going to rebuild it. Will also change all 4 rotors as I was planning to do that this year.
Post #649310 27th Nov 2022 7:51pm
Sandyt
Which parts did they replace?
Post #651350 21st Dec 2022 10:40am
