Home > Technical (L322) > disappearing fault when switching engine off/on - p023d (22) |
RRR4J Member Since: 22 Nov 2022 Location: West Midlands Posts: 12 |
The fault was the there before and after the blank |
23rd Nov 2022 10:24pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
At what point were they blanked? have you tried removing them since the LR software was reapplied? there's a lot of balls in the air here.... |
23rd Nov 2022 10:32pm |
No not removed since LR software was reapplied. |
23rd Nov 2022 11:12pm |
The LR tech said all readings were correct when they checked after software flash. |
23rd Nov 2022 11:17pm |
What was the reason the vacuum valve was replaced? was there a defect or just a 'try this' type of reasoning? I'm just wondering if there was a defect, if it's worth checking again.
24th Nov 2022 7:20am |
Personally, I'd do a 'common sense' check on the pressure and temperature values, with a cold engine and if you can, immediately after a fault indication but before a restart. |
24th Nov 2022 7:23am |
Hi, the vacuum solenoid was easily accessible so it was just a try it out.
24th Nov 2022 7:53am |
When I say 'common sense' checks, I mean are the live values plausible? for example boost pressure should be close to ambient pressure with the key on, engine off, if ambient is 1000kpa and the boost pressure is reading 1005kpa, that's fine, if it's reading 1050kpa (or 980kpa), then clearly there's an issue. the same goes for temperature, although a warm engine will obviously have different temperatures in the charge air path to ambient, it's mainly to make sure the readings make sense for the conditions. |
24th Nov 2022 6:07pm |
EvolutionUK Member Since: 03 Jun 2024 Location: Hampshire Posts: 12 |
Hi chaps, I’ve recently moved into an L322. 3.6 08. I’ve done a basic oil and filter service, and replaced the air filter with a K&N filter. While I was in there I cleaned the sensors. I’m now seeing a fault code: P023D-22 (2C) Manifold absolute pressure - turbocharger/supercharger boost sensor A correlation - General signal failure - signal amplitude>maximum. On IID.
27th Jul 2024 8:16pm |
Did you ever figure out what was causing this? I have the same issue. Thanks |
17th Nov 2024 9:03pm |
