Home > Maintenance & Mods (L322) > L322 Stuck in 3rd Gear... the saga. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 |
The gearbox will go into limp mode if the engine is in limp mode, which is what seems to be happening.
21st Nov 2022 7:17am |
PraguePrado Member Since: 09 May 2022 Location: Paris Posts: 27 |
Thanks Graeme; so, just so I understand the meaning of "limp-mode", even in limp-mode, the engine will still go as fast as I can get it to go in 3rd gear? I thought limp-mode would cause the truck to not go past a certain speed.
21st Nov 2022 7:31am |
Engine limp mode limits fuel, whereby the engine will rev whilst there is little load but as soon as significant load is applied that would require significant fuel the revs will be quite low. In 3rd gear once speed increases the engine load is quite light so doesn't consume much fuel to rev. However some restricted performance events don't limit performance to the same extent as some other faults.
21st Nov 2022 9:17am |
Thanks again, Graeme - I think I understand the limp-mode description. And yes, I'm pretty sure that the turbos continue to work (despite any damage the hose blowing off may have caused, which isn't yet evident).
22nd Nov 2022 12:32am |
Are the codes still only the ones starting with U? Low voltage at the ECM can cause comms faults which have been found to be caused by a failing battery in other LRs, but possibly also a failing alternator. The alternators used by LR have a habit of short-circuiting their power diodes which are avalanche diodes that reverse conduct when voltage exceeds their trigger voltage which lowers with age thus eventually causing a dead short. Hence intermittent loss of charging capacity soon becomes a battery-destroying event. |
22nd Nov 2022 3:48am |
You've just reminded me that (thinking the alternator might be shot) I bought a new alternator, radiator, and gearbox oil cooler, with the intention of replacing all of them (I wasn't able to find out if the sludging issue with the gearbox cooler was still applicable in 2008, but thought what the heck).
22nd Nov 2022 4:36am |
Just an update for anyone who is interested.
24th Jul 2023 9:07am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8358 |
Wow, dodged a bullet there....
24th Jul 2023 9:37am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 |
“He would find someone to take it off my hands”
24th Jul 2023 10:21am |
Exactly.... although the fact that I could go 70mph in 3rd gear sort of gave it away... |
24th Jul 2023 2:03pm |
