Home > Maintenance & Mods (L322) > Heater Box Replacement LR010840 2011 L322
Peter B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Hi all
Due to my fan disintegrating I have been told I need a Heater box replacement for my 2011 Autobiography. Ouch. So far no local garages (Worcestershire) have managed to quote, except one at 36 hours £2,600, plus the part.
Does anyone know anywhere that might be willing to undertake this huge task? I am of course willing to travel.
Thanks Peter
Post #648236 16th Nov 2022 1:33pm
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
As per my reply to your post on the 405 thread, if you are handy with a dremel this might save you a fair chunk of expensive change..
Post #648244 16th Nov 2022 2:37pm
Peter B
Thanks for the video. My problem is too much work, not enough time and winter coming.
Post #648250 16th Nov 2022 3:35pm
marcochezzi
I can well understand..
While not the same, my air recirculate flap/valve on my 405 broke where the stepper motor that locates the flap inserts into said valve.
It too requires a complete dash disassembly and removal of everything up front, dreadful thought having someone do that to my fattie, so I opted to undergo the repair myself, quite literally through a keyhole, without removal of the unit.
I am not small in frame, I did get the job done, it has been working accordingly for the last 2 or 3 years, but if it gives up once again I'll simply mechanically shut the valve as recirculate, permanently..!!
Post #648253 16th Nov 2022 3:59pm
