![]() | Home > Technical (L322) > Suspension failure whilst driving |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 293 ![]() ![]() ![]() |
For the last few weeks I’ve had a few suspicions about my suspension: I noticed the car was sitting unevenly whilst stopped by what seemed to be 10 to 15mm at the back LHS. It was holding it’s height okay overnight and all else seemed okay so I decided to leave it for a while and do a guided suspension calibration when I next had time.
blackpool Member Since: 14 Aug 2022 Location: Blackpool Posts: 24 ![]() ![]() ![]() |
Hi Ramblin
Taken from https://obd2pros.com/dtc-codes/u0415/ But could even be battery related? Is your battery fully charged? |
Thanks @JayGee I’ll order one up and breakout the spanner’s and trolley jack.
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Sounds like the same issue I had awhile back, new sensor and all everything sorted. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2280 ![]() ![]() ![]() |
Just dont drive it till you do it or you might damage the pump depending on what it is being told to do |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
The free download workshop manual in the Wiki has all the DTC (diagnostic trouble codes) in a chapter |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Please excuse me if i am being an idiot, and I am not asking because I doubt your knowledge. But for future knowledge in case this happens to me, how did you diagnose a height sensor from that DTC and do you know which one? Thanks in advance! |
The height sensor fault was identified in the other thread. 2012 TDV8 Vogue (L322) |
Aaaah! Thank you. |
