Home > Technical (L322) > Bulletproofing a l322 |
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 67 |
If I was driving 2,000 km's a week I would be looking for something I would be able to service as readily and easily as possible. And perhaps not 20 years old? Seems like there's a couple of conflicting requirements here TBH. 2012 Supercharged L322 |
14th Nov 2022 9:24pm |
Deanogw Member Since: 05 Nov 2022 Location: Oxford Posts: 3 |
I have a 2014 hilux, have had landcruisers, rangers, jeeps dodge rams. None of them are cheap to service or maintain. Spent 3k fixing problems in a brand new landcruiser. 2k for new ecu in a px2 ranger. Jeep ate axles. I am mechanically capable. Ive found older vehicles to overall be better and longer lasting then anything new. used to do 3k km a week in a defender 130 |
14th Nov 2022 9:37pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
On the back of a recovery truck? |
14th Nov 2022 9:43pm |
Haha no. Only thing i ever had go wrong was a wheelbearing on one of the front axles went while i was out west. Drove 400km and replaced the half shaft. It was a tdi. Frequent preventative maintenance never really had an issue. |
14th Nov 2022 10:07pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
IMHO Bullet proof and L322 do not belong in the same sentence...
14th Nov 2022 11:50pm |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 162 |
buy B6 version. Maybe will fail like others, but instead will be few times more expensive to fix.
15th Nov 2022 7:50am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
I had a TD6 and had 1 major issue with it and that was the GB, it failed but not untill i had put on 25k. And had i serviced the GB it would probably have lasted longer than that.
15th Nov 2022 8:02am |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
I thought you were asking about actual armor Literal bulletproofing of the L322 is far more realistic an endeavor than figurative against breakdowns...
15th Nov 2022 8:03am |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
To the OP.
15th Nov 2022 7:24pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
I have run mine for 10 plus years and it is now on 230k + and it has never failed I do do a bit of preventative maintenance . Engine oil every 6k diffs and gearbox every 30k and anything slightly wrong with the suspension replaced before it goes wrong and I have to say it has performed magnificently |
15th Nov 2022 7:29pm |
