Home > Technical (L322) > FBH Season ! |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 |
So my FBH seems OK and runs when driving, however when i use the park heat function have now got this interesting noise coming from the wheel arch...
6th Nov 2022 3:20pm |
OK so I replaced the changeover valve (fiddly ) and the problem persists !!! So got the battery and tray out and I believe that there is an airlock as the noise is coming from the coolant pipes into the FBH. I suspect the coolant is getting so hot its effectively boiling. Ran the WTT test software and all the components seem to be testing ok, including the FBH water pump.
14th Nov 2022 5:48pm |
Quick update… I think I managed to get out the airlock as the FBH ran ok when I retried 👍 L322 2007 TDV8 3.6 |
14th Nov 2022 10:06pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
Be aware, water pump may get stuck sometime and no pumping (or pumping weak), and no error code at the same time due electric circuit is ok. |
15th Nov 2022 5:23pm |
