Home > Technical (L322) > T90/T91 Remote Availability/Alternatives? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1459 |
There was a topic on this recently:
10th Nov 2022 6:02pm |
Flybywire Member Since: 10 Nov 2022 Location: Warwick Posts: 4 |
Great thank you, must have missed that one - I'll give the local dealer a shout with the VIN and see what they say, with what people are asking for second hand remotes now it isn't worth the chance it might be the wrong one! |
10th Nov 2022 6:10pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7743 |
Oooo 1 more sleep….
Cheers both, I'll try firing up the FBH tomorrow manually to see if it works and go from there. I'm not averse to a bit of soldering and wiring and the phone ability would be nice - but might try the easy option first and see if the dealer comes up with the remote for this winter, then look at doing the GSM stuff for next year... |
10th Nov 2022 6:16pm |
I would. The other thing is that by the time a GSM gate opener and timer switch turn up from China, half the cold cold months are gone. 2015 Range Rover Autobiography 4.4 SDV8 |
10th Nov 2022 6:17pm |
You can still set it to come on at a set time using the screen in the dash, so if you know when you are leaving the house in a morning, you can still have the cabin a bit warmer.
10th Nov 2022 6:57pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
The original Telestart is very simple system: it gives +12V signal to start the FBH, thats it. No any Can-bus signal needed to start it. You can easy replace it with whatever you wannt. Just use some swich, or buy another Telestart, or use some kind of GSM solution by mobile phone, or just connect direct from battery some wire.
10th Nov 2022 7:36pm |
