Home > Maintenance & Mods (L405) > Accessing boot from rear seats |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7959 |
Mine has a ‘ski hatch’ - if you lower the arm rest, there’s a button in the top of the seat back that opens the centre section of the seat into the boot space. |
10th Nov 2022 9:51am |
FullFatDunc Member Since: 16 Aug 2015 Location: South Somerset Posts: 65 |
Thanks. Yes mine has a ski hatch but it’s not big enough to empty the contents of the boot and get the cage out.
10th Nov 2022 10:13am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35425 |
how about a remote [seat down] switch located in the rear passenger area ..or extend the whole seating switch from the boot to the front ... ... - .- -.
10th Nov 2022 10:48am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
What Stan says....
10th Nov 2022 10:52am |
Thanks Stan
10th Nov 2022 10:54am |
might be worth having a look in the WM and see if theres a manual pull lever for the seat down..or look at the seat construction for some way to disengage the rear of the seat so it folds manually.. ... - .- -.
10th Nov 2022 10:56am |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 293 |
I've not got anything useful to add but wanted to say this is a really good point that I'd not considered before. FFRR SDV8 Autobiography |
10th Nov 2022 1:22pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7831 |
Not got a 405, but I know folk with the 322 had dog cages with a door on both front and back, so you can still get the dog out if the rear of the car is damaged in some way.
10th Nov 2022 2:35pm |
Johnh Member Since: 07 Nov 2011 Location: Rugby Posts: 44 |
If you buy a Vogue you will not have this issue manual release with lever on seat |
10th Nov 2022 6:36pm |
How big is the cage / dog ? Can the cage be mounted against the ski hatch - then worst case you would 'only' need to cut a hole in the cage ? I'm lucky that our dogs are small enough to live on the parcel shelf with a half height guard. |
10th Nov 2022 6:55pm |
These guys seem to offer a rear escape hatch option - https://dogtransit.co.uk/shop/dog_transit-...2013-2017/
10th Nov 2022 6:59pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
For the very rare occurrence this is likely to happen, if your worried the simplest option I would take is a hammer under the drivers seat / or suitable steering wheel lock, and just knock the rear screen in - laminated or not a few whacks with a suitable implement will soon sort it 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
10th Nov 2022 8:40pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1208 |
I do not have an answer to this, but in the meantime it may be worth carrying one of the special small / seatbelt cutter / hammers for escaping through the car windows if trapped. See below link...
10th Nov 2022 10:50pm |
