Home > Technical (L322) > TDV8 Fault codes Help
Adi322
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Report post
Just Bought a IIDBT G3 and it has given me this list of faults...
ATCM Terrain reponse
U0401-94 (2f) invalid data from engine control module- component failure- unexpected operation
U0402-94 (2F) Invalid data from transmission control module - component failure-unexpected operation
U0416-94 (2F) Invalid data from vehicle dynamics control module - component failure- unexpected operation
U0403-94 (2E) Invalid data from transfer case control module - component failure- unexpected operation
PBM Parking Brake
U0401-00 (2b) invalid data from engine control module
PCM Engine TDV8
P0088-00(2F) Fuel rail sysyem/pressure too high.
Any Ideas where to start as I am struggling with this now
Kind regards
Adi
Post #647708 8th Nov 2022 8:21pm
Most of them will be from low battery voltage at some point, delete them all and see what comes back, then you can ignore most of them unless you have a problem that coincides with a fault code... Thumbs Up Pete
Post #647711 8th Nov 2022 8:32pm
Adi322
Pete. They all come back up
Post #647715 8th Nov 2022 9:01pm
Does it run OK..?
What voltage are you getting with the tool, most look like low voltage issues, the failing battery gets pulled down when you start and sets the faults off....... Pete
Post #647724 8th Nov 2022 10:03pm
Phoenix
It looks like they're all cascade faults from 'P0088-00(2F) Fuel rail system/pressure too high'
That's the one that needs investigating. In the absence of other DTC's for components, then the actual pressure needs to be verified before going b@lls-deep into PCV/VCV checks.
Post #647727 8th Nov 2022 10:35pm
