![]() | Home > Maintenance & Mods (L322) > Fitting 2007 door cards to 2002 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7854 ![]() ![]() ![]() |
Can’t help directly, but I’d imagine the main thing to consider is where the air bags are located and if the door cards will give way in the same manner.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
I wouldn't... The airbag in the door won't act as it should in an accident situation... May even cause more impact damage to you or your passengers?
GUMBALLER Member Since: 22 May 2022 Location: Hampshire Posts: 40 ![]() ![]() ![]() |
Thank you |
Thank you |
