Home > Maintenance & Mods (L322) > If it helps. 4.4Tdv8 Starter |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
i hope it becomes a permanent repair.... but many have changed the starter motor, twice, and the problem returns... its mostly along the diagnosis, that the trigger wire, has a bad connection between the fuse box, and the motor. putting in a new motor, means the high resistance weak spot in the wiring is for a while, helped... but one day, it could return. i had the same. and tried two motors. in the end, a permanent repair was made, by running the external parallel wire method. there is a thread on this subject. -at least you know that the actual starter is not suspect now. |
1st Nov 2022 12:15pm |
Garymahoo Member Since: 15 Jul 2022 Location: Aberdeenshire Posts: 49 |
Hi John
1st Nov 2022 12:38pm |
