![]() | Home > Maintenance & Mods (L322) > Superpro Bushes |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
A potentially controversial topic…
If you’d like to do a bit of education and understand the differences between Superpro and other polybushes, this is probably the best video that I have found out there. 25 mins long, but really does cover a lot of ground and very useful info
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
Fitted them to my own D3, and a family members D3
Mikey, noting your legendary status in this community, that’s a HUGE endorsement and confidence inspiring to give it a go myself!
Fitting standard bushes to front upper and lower control arms and rear toe arms 'tightened up handling' significantly on mine but has made the ride harsher. One advantage of all of these aftermarket bush designs is that they are easier to fit that stock as they don't need pressing in with special tools. I've fitted polly bushes to other cars for this reason alone. 2012 TDV8 Vogue (L322) |
I cant compare handling, as I went from standard ARB's to Active Roll Control (Hydraulic ARBs), various RRS suspension arms, RRS front struts and D4 rears, as well as a full set of Superpros So it handles nothing like a Disco anymore ![]() It is, however, much more fun to throw around and surprises quite a few people unable to pull away from a small house ![]() |
So, about a year on from my original post I have finally fitted Superpro bushes to my front lower arms.
Great job! How much was the bush set for the front as I guess most people would opt to just reuse their existing arms? 2012 TDV8 Vogue (L322) |
I found all the parts from a company called ML Performance. All the parts were being offered at a discount when I bought this so I’d imagine it would be over £600 if one bought the same at full price. Here’s the order invoice
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 413 ![]() ![]() ![]() |
Great post, thank you for sharing |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2664 ![]() ![]() |
Some time ago I fitted for a very short time a 2-piece poly bush with a centre tube set (Powerflex) that I found unacceptably harsh on any surface that wasn't very smooth.
Graeme, they are single piece bushes with a separate outer sleeve a centre tube.
Thanks Ajmngn. |
SuperPro advised that the compound in these bushes is 80 Duro. Their range is 70, 80, 90 and 95 Duro.
