Home > In Car Electronics (L322) > BT Module repair
easylife103
England 2003 Range Rover Vogue Td6 Zambezi Silver
BT Module repair
Is there a repair service for a BT module on a MY12 Westminster?
The module only connects to my phone intermittently
none of the other parts of the infotainment system seem to be affected
Or do I need to source a replacement?
Post #643734 23rd Sep 2022 4:06pm
easylife103
Anyone?
Post #646486 25th Oct 2022 1:37pm
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
I had similar problems on my 2007 TDV8 3.6. Eventually it wouldn't connect at all. Someone on here suggested linking a different phone, then reconnect mine. Took 2 minutes and full connectivity restored for a year. Rinse and repeat. Might help. 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #646500 25th Oct 2022 3:23pm
harleyman
Spain
Hi, mine in my RR11 4.4Tdv8 seems only to work when the battery voltage is high
as these cars when you connect a AGM Battery it does not charge it al 100% the bluetooth module does not work, but if you connect an auxiliary battery is seems to work
looks as if low power is not good for the bluetooth 2012 Range Rover 4.4 tdv8 Autobiography
Post #646576 26th Oct 2022 9:05am
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I came to a similar conclusion with mine. Piece of crap!
Post #646580 26th Oct 2022 10:26am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
There are various services that appear if you do a Google search for "car ecu module repair".
I've never used any of them, so the challenge is to maybe get recommendations / confidence in one if you go that way Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #646585 26th Oct 2022 1:26pm
doesnt member baris repair these? ... - .- -.
Post #646586 26th Oct 2022 2:01pm
