![]() | Home > Technical (L322) > Alternator diagnostics |
Forget charge rate for now, look at quiescent / parasitic current drain. anything more than 50mA (thats 0.05A) is a problem, and really anything consistently over 40mA should be investigated. |
Rog21 Member Since: 09 Nov 2018 Location: Havant Posts: 62 ![]() ![]() ![]() |
Looks like i need to buy a current clamp then, any recommendations?
Yep, don't bother - the consumer ones are not great for low current as they tend to give false readings after an hour or more, if you have a multimeter with a proper Amps setting, use that, oh, make sure it has fresh batteries, a peak reading hold setting and a way to disable auto power-off.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Don't forget some sponsor Glenrands up the A3 in Passfield if you need a great local independent specialist |
An update,
What is the resolution of your current clamp? As I mentioned, 50mA is the upper limit, you need to look at peak and quiescent current draw over a number of hours - remembering that the EAS will 'wake up' to do a periodic level check & correction, it's not a quick job to do properly. |
The unit claims 0.001 amps on the clamp but I doubt it can. I suspect its more like 0.01.
A 10mA resolution isn't great when one digit out can put you under or over the 'there's a fault' threshold, my own clamp meters have a resolution of 1mA DC across different scales but TBH I still prefer to use direct measurement for anything lower than 500mA, mainly due to the amount of electrical noise that can be picked up and lead you down entirely the wrong rabbit hole....
Thanks for that, not sure how you measure the voltage drop as you would have to be in the car with it locked and internal motion alarm disabled. Also from memory the blade fuses stop you accessing the slots when they are fitted. it might be easier to pull the fuse and measure current across contacts with a meter. L322 4,4 TDV8
Push the door latches across so it thinks the doors are closed and use the key functionality to lock without interior protection, you measure the mV across the fuses with them in place to determine the volt drop across the fuse (by virtue of it's resistance) and use the tables to give an indication of current flow. Don't go pulling fuses as that will in most cases 'wake up' various modules and lead you down entirely the wrong path.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Just circling back to the battery point.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Alternators have a common habit of discharging the battery so could be at fault so a replaement may solve both charging and discharging problems. |
Alternator rectifier pack failure is not what i'd call 'common' - and would be certainly draw more than the 0.05A that is being measured. Alternator diodes only convert AC to DC, it's the regulator pack (commanded by the ECM) that controls the output voltage.
Morning update,
