Home > Technical (L322) > Air Bag Light on. 2007 Vogue SE (Fixed)
KDavies3
United Kingdom 2007 Range Rover Vogue SE TDV8 Barolo Black
Hi all,
My air bag light has come on (Red).
I have scanned the system and get the following DTC code.
B1195-87 Intermittent
Passenger Side Frontal Acceleration Sensor
I have tried clearing the code but it won't clear, so I'm assuming it's a real fault?
Does anyone know where this sensor is?
Many thanks in advance.
Post #570720 23rd Oct 2020 11:20am
KDavies3
Just for anyone interested, I fixed the problem.
The offending air back sensor was located behind the left hand front headlight.
Replaced it with one from eBay (searched the part number).
Reset the code and now all good it seems.
Post #571121 28th Oct 2020 10:27am
thanks for the update.. Thumbs Up ... - .- -.
Post #571126 28th Oct 2020 11:00am
DanRRL322sc
I’ve got the same problem on my 2007 SC. I don’t suppose you know the part number for the replacement?? Thanks.
Post #645296 10th Oct 2022 7:04pm
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Same problem just popped up on my 2013, 405, not sure where the sensor is yet 😡
Post #645363 11th Oct 2022 12:53pm
DanRRL322sc
Job done!!! I put the scanner on it and it was intermittent power interruption to SRS sensor. I disconnected the battery, touched the + and - leads together to dissipate any charge, cleaned up the terminals and the connectors, put it all back together. Started the car, steering lock full both ways a couple of times, switched off, cleared the fault, re-tested and now all is good Thumbs Up
Thanks for all the help and valid suggestions Very Happy Dan.
Post #646362 24th Oct 2022 12:29pm
