Home > Technical (L322) > Engine idle - nothing happens
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Hi everyone!!
Since last friday, my car has started to develop some kind of strange symptom.
Issue is:
When I start the car after it has been stopped overnight, the engine doesn't fully go to the 750-800 rpm idle speed.
Engine starts, but it stays at around 500 rpm. When that happens, everything seems dead. i can press the throttle pedal fully, move the gearbox leveller, but nothing happens. The car just seems to be semi-dead. Engine just sits there working like a generator, just going vum vum vum vum vum almost chocking...
If i restart the engine, then everything clears out and the car is back to normal.
Anyone has any idea on what I may be facing?
Post #646335 23rd Oct 2022 9:55pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Suggest you say what engine and year of car for people to advise you. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #646342 24th Oct 2022 5:08am
VMPP
Yeah.. Laughing Laughing
2007 3.6 tdv8
Post #646354 24th Oct 2022 11:35am
First thing to do is try a battery reset.... Thumbs Up Pete
Post #646360 24th Oct 2022 12:51pm
VMPP
That's one of the last things I want to do... as the car is with the steering lock problem active... Laughing Laughing
If I disconnect the battery, I'll have to be once again pour 3 litres of wd40 in the steering column to make it work. Always knowing that there's one day that, that solution won't work! Rolling Eyes
Post #646377 24th Oct 2022 3:25pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Could that not be causing the issue?. Whistle
Post #646391 24th Oct 2022 4:34pm
