![]() | Home > Technical (L322) > Gearbox problems |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
Search cattle grid on here, loads of info about it, only needs a TC not a complete box... Pete
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
No coding required.
HS66 Member Since: 22 Jun 2016 Location: Surrey Posts: 73 ![]() ![]() ![]() |
What is the rough cost of replacing the torque converter?, if anyone knows of a garage in the SE that offers a replacement service I can point him in the right direction, I sort of hope he does keep it as the rest of the car is in pretty great condition for a 2007!. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Take it to Dartford Transmissions and Autocare for Martin Hind to look at it.
So first call was trying some of the anti shudder stuff to see if that sorted it out a bit, problem was the gearbox filler plug has completely rounded off and it’s on so tight even a hammer and chisel can’t get it to turn, friend has pretty much given up and decided he’d rather cut his losses. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
If you search ZF 6 HP torque converter, there's several sellers who refurbish them online and especially if you send off your old one after, can be had quite affordably. Then it's just the task of separating the box from the engine and shaft to the transfer box in order to replace it. I'm unsure of garage time but would expect it to be a day's work, so would expect a total bill in the region of £1,100 (£400 for the torque converter plus labour). Garages quoting silly money won't want to do it because the vehicle will take their ramp all day and they can make more money from lots of small servicing jobs. 2015 Range Rover Autobiography 4.4 SDV8 |
