![]() | Home > Technical (L322) > L322 Upper tailgate draining rainwater when opened. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Yep.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
After a good wash down, I gently lift the the tailgate allowing trapped water to escape slowly……otherwise, if the brain isn’t engaged in time there’s a whooosh & the parcel shelf gets a bit of a splash! Annoying having the odd water stain on the parcel shelf. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Mine just drains down the left side. Not sure where it's accumulating - is it a blocked drain hole? 2012 TDV8 Vogue (L322) |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
Have just got used to it now its normal |
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 77 ![]() ![]() ![]() |
I've always been amazed this hasn't caused a major issue from water pooling then freezing, but so far no issues. Fingers crossed it doesn't! 2012 Supercharged L322 |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 ![]() ![]() ![]() |
It might be that the high level brake light seal is leaking. I have two almost identical L322's. I replaced the high level brake light in one and it doesn't leak and have yet to replace on the other and it too has water in the upper section of the tail gate.
Westminster_Bri Member Since: 17 Jun 2019 Location: Gloucestershire Posts: 31 ![]() ![]() ![]() |
Mines exactly the same, open the tailgate, stand back and watch it drain out the left side |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 282 ![]() ![]() ![]() |
When I replaced the high level brake light I took the opportunity to drill a 4mm drain hole on each lower corner of the “under tray”. I used Hammerite to rust proof each one. The result, no more sploosh when the tailgate is opened after rain. TDV8 4.4 2012 |
My high level brake light has a few led bulbs not working so may look at doing this when I replace it. 2012 TDV8 Vogue (L322) |
easylife103 Member Since: 04 Feb 2015 Location: Warwickshire Posts: 26 ![]() ![]() ![]() |
Catches me out a lot |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 881 ![]() ![]() ![]() |
could you take a few photos for me, I would like to do this mod - has it so far done the trick ??? could you indicate ( or measure ) how low down on each corner you drilled, or does it not matter too much in the scheme of things NB I am in the habit of holding the tailgate and letting it up very slowly, but when others drive the car they forget ![]() which is why my ivory parcel shelf is stained a bit, so I am keen to get the holes drilled and then steam clean my parcel shelf and hopefully it will not look so shabby ! |
@pcourtney I took some photos of the rear new brake light but unfortunately not the new drain holes. It’s tricky to see now as the whole thing is refitted.
that is very helpful, thank you, I will attempt this whilst trying to get my rear wiper washer working again - I think the two nozzles are blocked and getting a little pin in there to push in any dirt further into the nozzle did not work |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
Old topic I know, but to answer that last question on the rear washer wiper holes which get blocked up - here is a workaround. It works fine.
