Gearbox issue please help for a freind | |
Good afternoon everyone, I'm asking for some help with a friend's RR it's a 2007 RR Vogue. Recently it started to "Rattle" horrendously in "D" if you hold it on the brake, it's definitely gearbox related, oil and filter has been changed 3k ago prior to him buying it. It's just been redone since a garage suggested he try "that" to resolve the issue.
If the RR is sat on the drive in "P" it's fairly smooth tickover , if you go for a drive in it, it goes up and down the gear ok. It just start to Rattle and try to jump forward when say you stop at lights and hold in by the foot brake. It also does the same if you select "D" on the drive way and hold it by the brakes.
The screen shots are of the diagnostics at his local garage, but they couldn't offer any advice as to what to do to cure it?
Could any of you guys suggest what he could look at doing to try resolving the issue. I have no experience of automatic gearboxes, so can't offer any advice to him.
Regards as always.
| Click image to enlarge |
| Click image to enlarge | Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
