Home > Maintenance & Mods (L322) > Auxiliary Sockets : How to convert to ignition control
silentdrew
United States 2005 Range Rover Vogue 5.0 SC V8 Zermatt Silver
Ok thanks so much.
Once its stops raining I'll go try it.
I don't need the rear seat heaters at all, so perhaps I could pull the relay in position 6 and use that in position 1 instead of using the relay in position 2? They are both the same sort of relay with the wiring on it "++05051 2A"
Post #645369 11th Oct 2022 1:33pm
Use whatever relay suits you best. Thumbs Up
Post #645370 11th Oct 2022 1:35pm
silentdrew
It worked!
Thanks so much for you help.
In the end I used the Position 6 relay (Heated Seats) for Position 1.
And then I found an extra 4-pin 30Amp Relay that I put into Position 6, so everything is working now.
Post #645374 11th Oct 2022 1:47pm
Jolly good. Thumbs Up
Inexpensive fix for a RangeRover.
Enjoy your car.. Very Happy
Post #645375 11th Oct 2022 1:51pm
jeremy156
Unfortunately my 2011 model has a different layout, so I guess this is only for earlier cars.
Any thoughts on how to achieve the same on a later car?
Post #706095 4th Dec 2024 4:44pm
