Home > Technical (L322) > Strange issue that I cant get answers to. Help needed. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1452 |
Sounds like your starter motor is on the way out.
11th Oct 2022 8:25pm |
Smitch Member Since: 05 Oct 2021 Location: North west Posts: 40 |
Agree with garyRR I had a similar issue that was found to be the starter motor. They can be reconditioned but best if just replacing it with a quality Denso unit |
11th Oct 2022 8:33pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Check the wiki, there's a description of how to replace the starter.
11th Oct 2022 9:55pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I would also have a look at the Key Barrel. There was a common problem on the FFRRs where the barrel was at fault, had it happen to me with my old TD6, where the key would turn, all lights, etc., would illuminate then nothing but a click. I cleaned out the key barrel and sprayed some contact cleaner into it. Hey presto, worked perfectly without any problems.
13th Oct 2022 5:31am |
