Home > Technical (L322) > Reduced performance DPF filter full. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
Maltings are a Land Rover dealer and have them back in stock:
10th Oct 2022 7:51am |
SETDV8 Member Since: 30 Apr 2022 Location: Kent Posts: 20 |
Thanks for the info Gary.
10th Oct 2022 8:52am |
Maybe they were looking at the old part number?
10th Oct 2022 8:55am |
I think the fella I spoke to might well have done. I've just tried calling them back but he must be busy. I'll try again shortly. |
10th Oct 2022 9:01am |
https://www.ebay.co.uk/itm/272916567335?ch...ArEALw_wcB 2015 Range Rover Autobiography 4.4 SDV8 |
10th Oct 2022 9:15am |
That's not the part Gary. think that's the plenum chamber. The part I need is the nearside inlet manifold. |
10th Oct 2022 9:18am |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
SETDV8, how clean/dirty was your old inlet manifold inside?
12th Oct 2022 6:36am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3176 |
here are the part numbers for my recent nearside inlet Manifold replacement (with an updated part for the manifold)
12th Oct 2022 9:09am |
The part arrived, out of the blue, last Tuesday. Got the car back on Friday and all is well.
17th Oct 2022 7:35am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
2012 TDV8 Vogue (L322) |
17th Oct 2022 7:48am |
hawkeye651 Member Since: 21 Oct 2019 Location: Melksham Posts: 23 |
Thanks for the advice Gary. DPF Full light on the dash. Checked the Gap IID Tool code - D2459-65 Diesel Particulate filter regeneration frequency - algorithm based failure - signal has too few transitions/events. Cleaned out the MAP sensor which was very crusty - hence code above. Checked at the hoses which were fine. Put in a shot of DPF cleaner into the tank. Ran the car for 20 mins at ~2500 rpm. Light cleared on dash and on IID Tool 2012 L322 4.4 TDV8 - Current 2012 AM Rapide - Current 2009 Discovery - Gone |
26th May 2024 8:27am |
