Home > Maintenance & Mods (L322) > 5W 40 Oil in a 4.4 TDV8
2010BlackL322
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Santorini Black
All,
With 150K miles just passed, anyone got any thoughts of using 5W 40 oil in the TDV8 4.4?
Anyone moved on up?
Seems D3/4 owners have in their V6’s
Thanks Check out my YouTube channel
https://youtu.be/UHBbLWZXw4A
Post #645173 9th Oct 2022 11:28am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
More important to use low sulphur C1 if you have a dpf.
Personally I stick to what manufacturers recommend
Can’t imagine a low sulphur 5w40 will hurt it if that is what you are topping up with
And probably best to change more often that official service interval. I aim to change every 8k or less.
Post #645178 9th Oct 2022 11:50am
2010BlackL322
I change the oil and filter every 5k’s or after a major trip. Gearbox, transfer box, diffs etc every year around MOT time, that’s the schedule I’ve used with my vehicles. Doesn’t hurt.
Don’t think it would hurt it either. Check out my YouTube channel
Post #645182 9th Oct 2022 1:09pm
garyRR
The difference is a D3 doesn't have a DPF
Using oil other than to the standard Land Rover specify, you do at your own risk, as the DPF is very sensitive.
This is what the workshop manual specifies:
5W-30 STJLR.03.5005 only for 4.4 TDV8 DPF vehicles.
Many of us 4.4 TDV8 owners on here perform an oil change every 5,000 ‐ 7,500 miles and alternate that with a full service, which should be enough. 2015 Range Rover Autobiography 4.4 SDV8
Post #645205 9th Oct 2022 5:46pm
JayGee
150k miles - it's just run in. Do not change viscosity. Thicker viscosity does not = better engine protection. The main way (as others have said) to prolong life is to change more regularly as the life limiting factor in diesel oil is soot load. 2012 TDV8 Vogue (L322)
Post #645242 10th Oct 2022 8:55am
