Home > Technical (L322) > LH Chain noise 4.4 TDV8
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Morning peeps.
Been looking at a few minor issues that have been on the list for too long, but found a new one to add. However, I need to know how concerned I should be, what it could be, and what is involved in rectifying it.
The issue, as per the post title, is that there is a rattle from the right side of the engine. Closer inspection suggests it’s the LH chain/gears (on the right as you face the engine) and it sounds slightly rattly, or tappy. The other side is quiet in comparison. This is at idle (can’t reach the peddles with my head in the engine!) and only noticeable when you are close to the engine due to the other typical noises.
Oil level is good and only a few thousand miles old, was a warm engine, and was on a level surface.
I have a few concerns with my HPFP where I sometimes get vibrations from the fuel supply pipe, but don’t know if related or coincidental.
Any thoughts on this? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #645156 9th Oct 2022 9:22am
garyRR
Are you sure the noises you're hearing aren't from the tensioner and/or pulleys for the auxiliary belt? The tensioner does eventually wear out and starts to make noise and is off-centre right as you face the engine bay.
You should be able to get a hand or long screwdriver down there onto the tensioner and feel any vibrations. 2015 Range Rover Autobiography 4.4 SDV8
Post #645158 9th Oct 2022 9:43am
kevinp
I had a similar noise and I 'think' it was the fuel pump. Sometimes it sounded horrendous and sometimes quiet. I put in some good quality fuel cleaner and I've never heard the noise since. Worth a try?
Kev.
Post #645159 9th Oct 2022 9:58am
Ffrr-lover
That’s a good shout. I replaced all pulleys and the tensioner within the last year with genuine parts (although chirping has returned from somewhere near my alternator). I don’t thing it’s from the tensioner as it is certainly louder near the engine block itself.
As I’ll be tackling that other chirp soon I’ll run the engine briefly without the belt to confirm. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #645168 9th Oct 2022 11:52am
Ffrr-lover
Kev.
I do have some engine treatment which you put in the fuel tank… I’ll give that a go. No harm in trying!
What cleaner did you use? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #645169 9th Oct 2022 11:54am
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
How did you go with the noise? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #662826 25th Apr 2023 11:05pm
Ffrr-lover
Hi ffrr14
Nothing more has been done directly with this issue. The noise remains the same and am monitoring it for the time being should it get worse.
I have since posting re-replaced my belt, and re-replaced my fuel filter, which has solved other noise issues…
I guess its chains or guide getting a bit tired, and don’t want to tackle that issue right now. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #662947 27th Apr 2023 5:32pm
