Home > Technical (L322) > Battery terminals
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Battery terminals
Hi all,
Dont know whether this pertains to my other problem(key wont work).
My battery terminals are just a pooftenth smaller than what I can tighten the leads to it.
Is there anything that I can slip over the terminals,or a connector so that I can tighten the leads up "tight".
Thanks in advance
littlecub
Post #645129 8th Oct 2022 9:49pm
garyRR
Battery terminals are known to shrink as a battery ages.
If it's not a new battery, consider a new one.
Otherwise, all you need is some battery terminal shim/sleeves. Widely available. 2015 Range Rover Autobiography 4.4 SDV8
Post #645137 9th Oct 2022 12:37am
cass
I just use some fine copper wire stripped from any old cable I can find
Post #645140 9th Oct 2022 1:19am
