Home > Technical (L405) > Heater matrix - no cabin heat |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
Heater core might be part number LR036364 from what I can see. Looking at pictures of it, I cant see that there should be any valves in it blocking flow when the car is off. That being said, I don’t think I’ve known heater cores to block up as such personally.
6th Oct 2022 10:54pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
It usually gets blocked if the coolant mix is too weak (too much water = corrosion = rust particles) or the coolant hasn't been replaced or mixed with the wrong type of coolant.
7th Oct 2022 7:23am |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 94 |
That white curved concertina like panel is the air recirculate flap.. Mine was broken where the stepper motor connects to the unit, why I have no idea, but in essence it just flopped about in the casing adding no real value..
7th Oct 2022 11:11am |
