![]() | Home > Maintenance & Mods (L405) > Battery charging |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35484 ![]() ![]() |
Sacimiddx Member Since: 01 Aug 2015 Location: Hants Posts: 43 ![]() ![]() ![]() |
Thanks Stan
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2592 ![]() ![]() |
Had no problems with a maintenance charger connected to the posts under the bonnet. |
Dave G Member Since: 30 Jul 2020 Location: Dorset Posts: 84 ![]() ![]() ![]() |
I have been connecting my C-Tek to these terminals for 6 months now with no issues 👍🏻 2013 Range Rover Autobiography 4.4 SDV8
Thanks gents |
1JBS Member Since: 18 Feb 2014 Location: Henley on Thames Posts: 172 ![]() ![]() ![]() |
Evening all
recordman Member Since: 08 May 2013 Location: Kent Posts: 116 ![]() ![]() ![]() |
I use a CTEK MXS5 for battery maintenance, not sure how long it would take to charge a battery from flat, indeed if it would do it at all. I charge it through the terminals under the bonnet.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1588 ![]() ![]() ![]() |
Hi, the CTEK MXS5 is a 5A charger and can charge up to 110Ah from flat OK, and can maintain batteries up to 160Ah.
Other than the risk of forgetting it's connected, I can't see why not, on the 12S socket pin 4 is a terminal 30 connection, as long as the charger rating doesn't exceed the rating of the wiring of course. Pin 2 is a terminal 15 connection, specifically for charging the battery in your tin tent so I can't see how current flow in one direction is OK but not the other, albeit on a different connection. |
Just a related issue, re AGM batteries and CTEK chargers, do NOT use the “”RECOND” mode at all, the 15.8V output will damage the battery, (refer to WM, “the battery maximum charge voltage should be no higher than 14.7V”
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Interesting stuff BUT contrary to what you say, the information you posted says quote "Reconding an AGM battery does not harm the battery".
@AJGalaxy
Ah I see, it was from the message you posted it seemed to be contradictory. BMW i3 Electric Car
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Just as an aside....I believe my Son's transit connect has stratification. Only heard about this a couple of day ago. Apparently the battery can show fully charged voltage but rapidly looses CCA capacity. His car does the 'dead battery click' when starting even though the voltage is tip-top but jumps starts without any issues. The article I read mentioned gently tilting the battery for a few hours before charging can help (done safely of course)- I assume to remix the chemicals before recon.
