Home > In Car Electronics (L322) > Update on Navtool |
rscsmith Member Since: 07 Aug 2022 Location: Sussex Posts: 27 |
Thanks |
4th Sep 2022 7:28pm |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 |
Anyone looking for a Navtool?
7th Sep 2022 9:56pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
Tymh - take a look at my Bluetooth install guide. Look at steps 5 and 9. A neat way of hiding a 3.5mm Jack cable and being able to close the lid. Just buy a 3.5mm female-female coupler to make life easier.
8th Sep 2022 9:40pm |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 284 |
Result - cheers |
8th Sep 2022 10:27pm |
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 69 |
Navtool's email response says version 6.0 with wireless carplay and Android auto for MY12 is available. My concern is installing this myself. Is it relatively plug and play as advertised? I'd also love to know whether I could route the audio through an Invery BT adapter instead of using the AUX port. |
2nd Oct 2022 1:10am |
It is truly a case of connecting a few cables. Take the nav unit out of the frame to access the connections at the rear. The audio output is twin phono, but the supplied cable isn’t long enough to reach the aux port so I routed mine under the carpet. That was the longest part of the job! Tym
2nd Oct 2022 7:23am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
It’s completely plug and play. Very straightforward. You have to take the nav unit out (couple of bolts) to access the rear sockets.
2nd Oct 2022 7:26am |
Tym (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
2nd Oct 2022 10:13am |
Thanks for the input!
2nd Oct 2022 11:43am |
Hi Tymh, Weegie
2nd Oct 2022 5:47pm |
@rob
2nd Oct 2022 6:16pm |
Great. Thanks Tym.
2nd Oct 2022 7:20pm |
Ugh, just saw this - if the remote is required for input and the touchscreen input is unavailable, well that's a dealbreaker for me (MY12) 2012 Supercharged L322 |
8th Oct 2022 1:21pm |
DanPoole Member Since: 01 Mar 2017 Location: Kent Posts: 59 |
Hi Tym,
10th Oct 2022 4:37pm |
