Home > Maintenance & Mods (L405) > Centre console cup holder cover |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 |
It sounds like its broken, it should slide forward with minimum effort and stay in place. |
1st Oct 2022 2:50pm |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
Anyone know where I can obtain a centre console? |
2nd Oct 2022 9:10am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1401 |
It should slide to its limit and then latch in place. You then give it another push to unlatch, and it'll slide close. cant be worth getting a whole centre console for what is likely just a small latch thats needed.
2nd Oct 2022 9:40pm |
405, is a 2013 model, thanks for the info, I’ll start searching |
3rd Oct 2022 9:54am |
LPG Member Since: 20 Nov 2012 Location: Kent Posts: 15 |
Hi, I have a 2013 model with exactly the same issue. The slider does not stay open.
19th Oct 2022 10:39am |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 287 |
I suffered with a spilled sticky drink last year which resulted in me needing to take the cup holder cover and various other bits of the centre console apart. It was a medium-tricky task to do this but I did get it all back together.
19th Oct 2022 6:16pm |
Sorry just re-read and seen that you’ve got the opposite problem, ie the springs work but the lock doesn’t.
19th Oct 2022 6:20pm |
