Home > Maintenance & Mods (L405) > Help!! Suspected gearbox oil leak or is it!
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys any ideas where this slight oil drip is coming from see image attached.
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #644302 29th Sep 2022 12:28pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Looks like you have a transfer box leak there, not uncommon on these and usually a very slow leak so don’t tend to be that urgent. (Mines had one for three years). The level is easy to check by removing the 8 mm hex plug in your picture, it should drip once removed when full.
Post #644395 30th Sep 2022 11:50am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Definitely the transfer case. Looks like a new copper washer might fix that. While you are at it, get two copper washers and 2L of fluid, and change it. Some brake clean after on the housing and it should be good to go. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #644431 30th Sep 2022 5:43pm
jaysta10k
Cheers for the advice I will get transfer case fluid done then address the leak next week.
Previous Cars
BMW M3 Carbon Black
Post #644436 30th Sep 2022 6:45pm
