Home > Technical (L322) > Invisible oil leaks... 4.4 TDV8 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3256 |
Sounds like either the gasket or the cooler have a leak if there is oil in the coolant - almost inevitable on these engines. 2012 TDV8 Vogue (L322) |
24th Sep 2022 11:01am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2501 |
There are 2 coolant fittings where people have found the o-rings perished. 18mmx2.5mm Viton o-ring has been used on the one at the oil cooler and the other appears to have 18 x 3.0 marked on the housing which could be the o-ring size. I've sourced both sizes with the idea to replace both when I investigate the cause of a slow coolant loss. I've already replaced the cooler gaskets. |
24th Sep 2022 11:25am |
fmgl322 Member Since: 18 Apr 2022 Location: Koblenz Posts: 63 |
Thanks - how likely is it for the cooler itself to fail? Can it be tested or inspected in any way without tearing everything apart?
24th Sep 2022 11:36am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Replace the whole thing. Been known to warp.
24th Sep 2022 12:18pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1478 |
As Dr Rob says, the oil cooler is pretty well known to warp in a good proportion of cases. Even a good gasket can't solve that. 2015 Range Rover Autobiography 4.4 SDV8 |
24th Sep 2022 1:16pm |
Evening all,
28th Sep 2022 7:41pm |
Save yourself some money and just get some 70mm hose.
28th Sep 2022 7:44pm |
Where is the other coolant fitting? Pardon my ignorance - the one on the cooler housing is obvious enough, but where's the second one you mention? ------------------------- 2012 4.4 TDV8 Vogue 2001 Audi A2 1.4 16V 2019 Skoda Kodiaq (don't ask...) |
It's closer towards the front of the engine. |
28th Sep 2022 8:43pm |
