Home > Maintenance & Mods (L405) > Ceramic coating
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Just home after driving through some rain.. the dark area had the scratch… SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #611348 1st Nov 2021 8:56pm
Andy B
Re: coating
oggy wrote:
hi did you put the ceramic coating on top of the resin polish
Yes, the ceramic coat was on top of Auto-Glym super resin polish. This was applied following removal of contaminants using a clay mitt and detailing spray Thumbs Up Planning to do the Jag SC next, also Loire Blue Smile SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #611381 2nd Nov 2021 12:45pm
pcourtney
Bilt Hamber Auto Foam
just looked at my Sumatra Black in the sunshine today ( its really very very dark pearl blue, purple) , and so pleased I did the ceramic coating, all I do once every two weeks is "Snow Foam" some Bilt Hamber Auto-Foam, let it dwell for 4 mins, and pressure washer it off, then run the micro fibre mits over it till I'm happy - job done Smile
before the ceramic paint protection it would take me hours to get that showroom clean look, but now it takes just 20 mins
https://bilthamber.com/product/auto-foam/
Post #644137 27th Sep 2022 5:10pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
when you have done washing and moping dry go over with a detailing spray i use g3 pro 7193 detailer. i also use pure water on the final rinse through the power washer . then you do not need to mop dry and less scratching
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #644151 27th Sep 2022 6:48pm
pcourtney
nice SC - nice colour Razz
just had a look at the g3 pro 7193 detailer ( cost £10 for 500ml ) , this might be something I can try after one of my Auto Foam shampoo ( snow foam) washes, if it does make the Sumatra Black pop out more to my eye, then it will be worth doing
how often do you use 7193 on your car and how long does it take to spray it on and then buff using microfibrel ?
Post #644154 27th Sep 2022 8:23pm
oggy
hi you are supposed to use it after every wash and yes it is easy to apply just spray on a panel wipe over leave move to the next panel then go back and wipe off you will be happy with the outcome. okay, ref the filter it will work but not for long you do not have to buy loads of pure water you need to buy a canister that will filter the water as it goes through your power washer. or put it in line with a garden hose this is where i buy my filters from daqua from Scotland di resin water filters bigger the better bottle when spent out just replace the resin. the glass comes up like new and no staining much the same system as the window cleaners use final rinse and leave it dry then on with the g3 after fully dry job done and yes do the roof as well pain i no just get a good hop up .
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #644183 28th Sep 2022 11:33am
pcourtney
the filter I found in my garage - is INLINE with hozelock fittings - just like the one you have ( albeit yours is a bigger cannister by the looks of it )
Post #644186 28th Sep 2022 11:51am
dhallworth
Except Oggy's canister is filled with a DI Resin, not a filter.
Post #644189 28th Sep 2022 11:56am
pcourtney
got it, the old filter is no good anyway, so I will buy a new 10" DI Resin Holder Cartridge filled with resin
Post #644190 28th Sep 2022 12:14pm
oggy
hi your filter will work but not for long maybe a couple of washes ? my di vessel is the 23.6 ltr 8x 35 with the mb115 resin in it and you have to buy a water tester, not much money that will let you know when the mb115 resin needs replacing if you use ref garden hose you get about 80/100 washers put it in line with power washer you are like to get 50 washes . but none at the moment as we are still on hose pipe ban . so it is hand ball job at the moment .
just a chear up . Irishman decides to go to a car boot sale and drives in the wrong way and sells the engine are its the way you tell um Laughing new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #644191 28th Sep 2022 12:38pm
pcourtney
thank you
https://www.killerbrands.co.uk/products/di...k-fittings
Post #644193 28th Sep 2022 1:25pm
oggy
hi pcourtney very good link lot cheaper than my supplier this is what you need use this with your snow foam as well pure water all of the way you will have to put a pair of shades on after washing it you will have a nice set up . oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #644194 28th Sep 2022 2:06pm
