![]() | Home > Technical (L322) > L322 M62 V8 4.4 startup rattle |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 594 ![]() ![]() ![]() |
Hi everyone,
Thanks John,
Alejo Member Since: 28 Jul 2019 Location: London Posts: 2 ![]() ![]() |
Hi did this sort your issue ?
Hi, it was a combination of things. First of all the oil filter. Use genuine LR or MAN, the one with paper bottom NOT the ones with plastic. This will make a big difference.
Thanks will get those ordered and fingers crossed it improves |
HFFK Member Since: 25 Sep 2022 Location: Baku Posts: 3 ![]() ![]() |
Hi, maybe its too late for giving advices on this issue. But your rattle on cold start or after long time not running engine is in return valves but not those ones which located behind the vanos solenoids in engine heads. There is another two which are located in engine block under the engine head gasket. Those two non return valves stops the oil leaking from engine heads to the engine block. Number 5 on the image. ![]() |
Hi!
You are welcome.
With the amount of work it takes just to access these, It'd better not come back ever again. |
My decision is same)
Sorting various external leaks seemed to nearly eliminate the problem so that's encouraging. It would be frustrating having to tear down an otherwise
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 870 ![]() ![]() ![]() |
thanks for reminding me, just about to do an oil change on my old M62 ![]() |
You're welcome |
