Home > Technical (L322) > High pitched whirring noise
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
I have a high pitched whirring noise which appears to be coming from, what I can only describe as the top of the engine, under the plastic engine cover, on my tdv8, 3.6
It’s not there all the time, it can be several days between it happening, but it’s getting more frequent.
I’ve not had any loss of power, or smoke from exhaust, but could it be the turbos?
Cheers
Post #643683 23rd Sep 2022 10:50am
garyRR
Take a video, post it on YouTube unlisted and then put the link on here.
We also need a little more info on when it does happen, how if occurs. Is it when idling, cruising, accelerating etc?
The turbos are down the sides of the engine block so, if the noise is coming from the top, your only likely causes are the intake manifold and hoses suggesting an intake leak making the noise. The alternatives are one of the pulleys/idler on the auxiliary belt or one of the fuel pumps. 2015 Range Rover Autobiography 4.4 SDV8
Post #643707 23rd Sep 2022 2:10pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Idler bearing by the sound of it Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #643709 23rd Sep 2022 2:28pm
Wogger
Cheers chaps
Typical, it’s not doing it when I came to video/record the noise, I’ll try again, when it does it again !!
Post #643717 23rd Sep 2022 3:07pm
Wogger
Forgot to mention, it’s usually when under acceleration
Post #643724 23rd Sep 2022 3:25pm
