Home > Technical (L322) > Toasty Interior? Not really… |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
is the red/blue dial in the very centre set to the middle between red and blue, or is it all the way over to blue ? The dial is meant to be an offset to the temp setting on the main dials ... so if you have it to blue, then it'll blowing colder than what the dial is set at (upto 5degC difference I think ). Equally it can offset to a hotter temp if you push it towards the red. Having it in the middle means that it blows the same as dial setting.
22nd Sep 2022 12:40pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Which engine do you have? The bleed procedure is different depending on engine. No special tools are required for bleeding, so long as you follow the workshop manual steps. If it's the 4.4 TDV8, the bleed screw is slightly to the right of the expansion tank on a radiator hose. It's a big plastic plug with a cross head for a screwdriver in. Here's the bleed procedure for the 4.4 TDV8:
A point to note, there are other possible causes: - One could be the final stage resistor (hedgehog), although less likely on a car 10 years old - internal cabin temperature sensor (can be monitored with IID) and again, unlikely on the 2011-2012 cars which had a different climate panel to earlier cars - faulty pressure control valve on the air con compressor can also cause lack of cabin heat. I had a similar issue where the cabin would cool but not adequately heat almost at random in winter. The cause was the air con compressor. 2015 Range Rover Autobiography 4.4 SDV8 Last edited by garyRR on 22nd Sep 2022 1:16pm. Edited 1 time in total |
22nd Sep 2022 12:53pm |
fmgl322 Member Since: 18 Apr 2022 Location: Koblenz Posts: 61 |
Sorry, should have said, it’s a 2012 TDV8 4.4. The O-rings repair should have given it away!😂 |
22nd Sep 2022 1:14pm |
See above. 2015 Range Rover Autobiography 4.4 SDV8 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
I presume the engine is fully upto temperature. Cracking open the expansion cap with a fully upto temperature engine is a seriously dangerous thing to do. |
22nd Sep 2022 4:41pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1375 |
My 2012 TDV8 was fine and warm when the fuel burning heater was on (under 5 degrees external temperature) but above that the heating was a bit disappointing. Modern diesels are so efficient that they don't generate that much heat, and so need the fbh for colder times. You could also have a problem with the final stage resistor/sticking of flaps in the heating ducts and maybe replacing/freeing in that area could help. I tended to use the auto setting and generally just leave it at the set temperature, but when it was say 6 to 12 degrees and not sunny it needed to be turned up a bit, though not to max. Only Range Rovers since 1988 |
22nd Sep 2022 5:58pm |
Thanks for your replies so far.
22nd Sep 2022 6:55pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Thermostat stuck in the open position? BMW i3 Electric Car
22nd Sep 2022 7:12pm |
Thought about that (thermostat) but the engine temp rises normally and the top hose (bleed hose) only got hot once everything else was up to temp. I’m guessing the thermostat is working… |
22nd Sep 2022 7:16pm |
Thermostat may be working but at the wrong temperature? I had a Merc Sprinter that always ran with a decent temperature showing on the guage but the heater was rubbish unless it was working hard eg towing my caravan 2000kg.
22nd Sep 2022 7:19pm |
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 |
Hi there, a few of us have had issues with heating have a look at this post it may help and good luck.
22nd Sep 2022 7:47pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3142 |
My 2011 TDV8 had a cracked thermostat housing but registered normal 12 o'clock temp gauge position but the engine was running too cool. Fan was always on (signifying that it was reading too hot but in actual fact was way too cold.) Changed thermostat. All ok. |
22nd Sep 2022 8:48pm |
This does seem to be a common issue. I’m tempted to get the thermostat changed now. I’m going to be deep in the engine soon enough doing the oil cooler gaskets and donut hoses, so why not just add the thermostat to the (slowly growing) list of things to do.
22nd Sep 2022 9:34pm |
