![]() | Home > Technical (L405) > 4.4 sdv8 engine knocking |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3759 ![]() ![]() |
A bottom end knock is usually pretty evident what it is. At 95k miles it’s more than likely an Injector that’s off. Big V8 diesels don’t go wrong at that mileage unless they haven’t been serviced regularly or the wrong oil has been used. The trouble is many owners only do short mile stop start driving, the engine doesn’t get hot, the oil gets contaminated and heavy sludge builds up blocking the oil galleries and intake.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 753 ![]() ![]() |
They've had one chance to fix it, I would reject it and get your money back while you still can.
Guysdv8 Member Since: 25 Aug 2022 Location: St. Helens Posts: 4 ![]() ![]() ![]() |
Thanks Vogue, I was thinking along the lines of injectors/fuelling as the knock is virtually none existent at idle, and coupled with the surging under light acceleration it does point to a fuelling issue. I did miss out that before it went back to the dealer it was taken to my local indy who didn’t seem to have it long and diagnosed bottom end with a stethoscope at a cost of £180, but I wasn’t convinced it doesn't sound like bottom end a friend of mine came today expecting a loud knocking as much as he said it doesn’t sound right he also doesn’t think bottom end I may return to my local Indy if I can get more time off work pretty snowed under atm. I’ll ask the question if he plugged it in and if not can he do a live readout of the injectors and check those hopefully it turns out to be something other than new engine time. Also last mot to mot mileage was very low but there is service receipt at an un known garage rest have been done at jlr mostly or landrover independent. I’ll get the oil changed anyway as a precaution. Surging also seems a little more noticeable after a good open throttle on the motorway getting worse when you come off the slip and back to normal driving. |
That reads like a reasonably long list of things they’ve tried to fix… did they fix the other stuff willingly and well (if so, they sound like they’re trying to be reasonable)? When did you actually take possession of the car? You could ask them to agree for you to take it to a reputable independent specialist or to a main dealer for an informed diagnosis to be made, if the seller is not a RR specialist (diagnosis at their cost); and then when the diagnosis is made you can decide the “what next?” between you… you have rights under the Consumer Rights Act 2015 but it reads like reasonable efforts are being made to resolve the issues at this stage. Ps… on two important occasions you’ve not been present when the car has been delivered… wouldn’t be me leaving that to chance for a 3rd time… but each to their own ![]() Last edited by pld118 on 19th Sep 2022 3:32pm. Edited 1 time in total |
@cass thanks, behind the scene the finance company are dealing with it as after I tried to contact the garage last Thursday I was given the run around the persons I needed to speak to were miraculously in and out of meetings all day. I assume the fact them having it back has nearly elapsed the 30day time period then they believe I’m going to be left with the issue and a warranty claim, however the work that has been carried out so far I can’t complain, and ultimately I would like to keep the vehicle as I really like it so if I can find a fix then I’d be happy for it to be fixed and keep it. Cheers |
Well emailed the garage this morning with a video of the noise whilst cruising at 50 mph on the motorway, the knocking can be heard over the stereo and wind noise after them failing to call me back last week they have called me back this morning with an apology saying they will collect the vehicle again next week give me a courtesy car. They have offered a full 12 month warranty with a claim value equal to the value of my vehicle. So can I fault them for that effort ? Being it’s also a 6hour round trip to collect the vehicle saying that you’d think it would just have been rectified the last time it went back as nothing due to that issue has changed. Also anyone tell me what this is hanging down front right small rubber hose just noticed it tonight. Drain? Or should it go somewhere |
Can’t help you with the hanging hose but someone else will likely be along soon…
Mr John Paul Billson Member Since: 27 Oct 2021 Location: Northants Posts: 6 ![]() ![]() |
I have had a issue with a oil filter fitted and after about 1100 miles the filter collapsed and seized up the big end bearing. Any oil supply issue can spin a big end bearing causing a big end knock. |
