Home > Technical (L322) > Problems after garage work. |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 |
Just had the car in for some work after it failed the MOT, had the drop links done, front pads and discs, drive shaft boots, brake pipe and rear CVD. The garage advised the dash was showing the yellow seat airbag warning light was on, offered to keep the car to investigate but I needed it so said I would take it back on Thursday. The brake pedal has a lot of travel and feels spongy, the car has a flashing red dash above the near side front wheel on the 4x4 screen when put in access mode, looks like they haven’t calibrated the suspension.
16th Sep 2022 8:11pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Cant help with the other bits, but the Brembo brakes take a lot of bleeding. Manual says to put the ABS valve block into bleed mode, to get the air out. That said, that might only be if certain elements have been replaced. I had the rear brake pipes on mine replaced along with the master cylinder, and I had to take the car back for them to bleed again, as the pedal was as you describe.
16th Sep 2022 8:52pm |
Thanks for the replies, much appreciated. phoenix, do you make sure the battery is fully charged before disconnecting it or before reconnecting ? |
17th Sep 2022 5:16am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Personally I'd charge it up whilst still connected but it shouldn't matter too much, just make sure the key is out and all the doors are closed and it's had time to shut down 'gracefully' - about 20 mins should do it, before you disconnect the battery. Leave it disconnected for a few minutes and make sure you get the terminal back on without excessive arcing, if there are a few sparks, don't worry, just leave the terminal off for a bit longer and go again. |
17th Sep 2022 6:24am |
Thanks for that, it’s a 2010 so key in shouldn’t matter. As it happens I attempted to get to work today and the suspension warning light came on 2 miles away from home and the suspension lowered to the bump stops. I’m assuming the airbag when they’ve done the shocker hasn’t been seated correctly. |
17th Sep 2022 10:22am |
Check the height sensor is not loose / jammed - any DTC's? it's possible the sensor arm is not the correct way round.
17th Sep 2022 10:25am |
