Home > Maintenance & Mods (L322) > somethin' is fishy with my suspension... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8167 |
The height of each corner is controlled by the air bags... NOT the dampers...!!!
14th Sep 2022 2:52pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7781 |
You might be better finding a specialist rather than a dealer. Sounds like they want to change everything till the problem goes away, and have you pay. If they diagnosed the rear dampers, and it didn’t fix it… I’d be wanting my money back…
14th Sep 2022 3:50pm |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 |
My bad I wasn't accurate, excuse my poor wording
14th Sep 2022 4:06pm |
Ah, ok, no worries. Your English is a million times better than my French… 🤣
14th Sep 2022 4:25pm |
Changing dampers and airbags will not adjust or effect the ride height, the ride height is adjusted by the amount of air that is pumped into the airbags. This is controlled by the ECU for the suspension
14th Sep 2022 4:33pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Well if they've calibrated the height, then the issue may be the height sensor on that corner (possible mechanical, not electrical defect). There is some relationship front-to-back, but only diagonally, not same side. The tolerance is +/-6mm so it's just about possible that your 'drooping' corner is due to all corners being in tolerance but the tolerances combining to a negative visual aspect.
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
Well if his diagnosis after the rears we’re changed, that the fronts need doing why didn’t he suggest it in the first place. Smells of BS to me. Find another garage. visiting from www.rrsport.co.uk |
15th Sep 2022 6:58am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3178 |
If left for any length of time a leak won't dip in one corner as periodically the system wakes up and levels the car so a leak will gradually lower the whole car. A faulty height sensor will do this though as will a faulty calibration procedure as the car may think it's levelling itself but is infract doing the opposite. I have a 'theory' that when the car is raised on a lift or jack so that the suspension is stretched to it's full extent then possibly on old sensors this can upset the reading and recalibration is needed. Also The GAP IID guided calibration procedure is not as straightforward as described in the manual and requires an extra step to load the values by entering the other height control menu to set custom heights. I've had various similar issues with mine that have been resolved by recalibration using the GAP IID esp after the car has been lifted or it's been in a workshop and the battery disconnected. I'd also find another garage ASAP 2012 TDV8 Vogue (L322) |
15th Sep 2022 8:04am |
Hi,
15th Sep 2022 9:24am |
[quote="Also The GAP IID guided calibration procedure is not as straightforward as described in the manual and requires an extra step to load the values by entering the other height control menu to set custom heights. I've had various similar issues with mine that have been resolved by recalibration using the GAP IID esp after the car has been lifted or it's been in a workshop and the battery disconnected." [/quote]
15th Sep 2022 9:29am |
