![]() | Home > Technical (L322) > Judder at higher speed - brakes or something more serious? |
Is the judder only when braking? Touching the wheel to feel any heat difference after a drive is usually the giveaway for a sticky or seized calliper. 2012 TDV8 Vogue (L322) |
Richycsurfer Member Since: 18 Nov 2018 Location: Plymouth Posts: 44 ![]() ![]() ![]() |
No the judder is more pronounced when cruising - not braking. I will try and get a feel for temperatures later today. |
If it's been sat for a while you could have a flat spot on a tyre or tyres. 2012 TDV8 Vogue (L322) |
I did think tyre/wheel issues but the wobble/judder comes and goes. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3188 ![]() ![]() ![]() |
I’ve noticed similar on my 2007 at the moment.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
I think most likely this or a buckled wheel or improperly balanced wheel. Get the wheels checked at a reputable tyre garage who can check both tyres and alloy geometry. They can be difficult to see with the naked eye but easy to see on a balancing machine. 2015 Range Rover Autobiography 4.4 SDV8 Last edited by garyRR on 12th Sep 2022 11:15am. Edited 1 time in total |
I’m thinking it’s possibly a flat spot too due to the amount of time mine has been sitting whilst I’ve been working on it.
Take it to a good tyre garage and find out. Their experience and knowledge are usually free and invaluable. 2015 Range Rover Autobiography 4.4 SDV8 |
There’s a place locally that do road force balancing which I’m tempted to try.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
. Deleted by author. 2012 L322 4.4 TDV8 AB low mileage - a peach
Problem is, there’s not a bush or balljoint that’s not been changed on my car in the last few months. I’ve had it in bits from front to back and done everything with genuine parts.
Mine vibrated at speed when I first got until I had the wheels rebalanced. There's a lot of energy in those big wheels.... 2012 TDV8 Vogue (L322) |
It appears mine is the NSR caliper (or possibly flexi hose) so have ordered one and a set of pads to stick on tomorrow. Is the bleed procedure nice and standard on these or am I going to run into problems? A quick search appears to say I shouldn't... |
If it's repeatable, and you have someone who can drive a 'chase car', get them to look at the suspension oscillation, it may well be a weak suspension damper - this can give the same symptoms as the 'now it's there, now it's not' scenario as it depends upon the speed and something in the road surface triggering it.
