![]() | Home > In Car Electronics (L322) > 2008 GPS |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
Where do I find the GPS receiver in a 2008 Vogue please? The sat nav (that I’m not using but I want it right!) shows no GPS and there’s a GPS fault showing in IID.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3258 ![]() ![]() ![]() |
The receiver is integrated in the nav unit in the left rear cubby hole. A possibility is that your gps aerial on the roof may need replacing.
Thanks Weegie. If it’s a big job then I’m not bothered as I use CarPlay now anyway. I’ll have a search…
Thanks phoenix
USB one won't work... it needs data over power (co-axial connector) if you CBA to take the roof pod off, you could always blu-tack it to the trim in the boot next to a side window until you can 'BA'.
Thanks for the link Phoenix.
No worries - I tended to do some of the less-important jobs in lunch breaks at work so actually ended up doing them before the other jobs that needed more time / money investing in them! |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 724 ![]() ![]() ![]() |
Tymh i have a gps receiver i bought to plug into mine that you can put in the window. It's now surplus as I've just had a genuine roof antenna fitted to mine. It has the fakro plug so will plug directly into your satnav unit in the boot. £5 posted and it's yours. |
Thanks but for now I’ll pass. It’s not something hugely important and I’ve got other issues (not car related) that need my attention at the moment.
If the offer is open to anyone, I'll take it - No.2 Son has a Disco3 with non-functional GPS and it's the same Nav. unit. |
