![]() | Home > Technical (L322) > 2011 vogue drivers seat movement stopped working |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
I have the same problem on my 02-03 L322....does the tilt on steering column still work?
Richycsurfer Member Since: 18 Nov 2018 Location: Plymouth Posts: 44 ![]() ![]() ![]() |
The steering wheel movement fortunately does work!
Any more ideas or suggestions on tests I can do? When I bought the car the movement took a minute to spring into life. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
They have separate fuses for the motors in the front fuse box.
Thanks for the reply - fuses were intact and powered so after removing the side panel it was found that the smaller white multiplug had become loose. Seat now operating as intended! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
double post... Pete
