Home > Technical (L322) > Header tank removal and coolant drain
edward19
Hi All
I'm just on the last leg of getting my 4.4 TDV8 on the road and need to sort out the phantom low coolant warning. Apparently removing the header tank, cleaning and refilling with fresh coolant is the way forward and I wonder if anyone has an extract from Topix showing how to do it. I'd be very grateful if someone does.
Thanks
Post #507981 8th Mar 2019 2:45pm
johnboyairey
I have this job to do myself.. is it straightforward to remove please.
Post #642523 9th Sep 2022 4:22pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Not a major job. I replaced the header tank with a new one as you can't buy the sensor on its own. Malting 4x4 do one at a very reasonable price.
Assuming you're working on a right-hand drive vehicle, remove the intake pipe and airbox on the driver's side.
You can now get at the relevant clips and bolts to release the header tank. You'll lose some coolant but just follow the bleeding instructions and all will be well.
Airbox out;
New tank installed;
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #642679 11th Sep 2022 2:00pm
