Home > Technical (L322) > 2012 Westminster Deployabe side step removal for jacking |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35287 |
i used to jack up on the inner bracket without any problems.. ... - .- -.
3rd Sep 2022 4:06pm |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 119 |
As do I. The Land Rover specialist I brought from advised that’s the best jacking point, and is what they used when it went up on the ramp to sort a few bits for me. |
3rd Sep 2022 4:26pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 584 |
I thought the bracket was a jacking point on the 405 but not the 322??? I couldn't even remove the 4 allen screws on mine and instead just used to open the back door so the steps stayed deployed, then used the normal jacking position. I'm sure that's got some risk associated, but worked for me changing summer to winter wheels and back for about 8 years. Mike - MPx
3rd Sep 2022 4:36pm |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 111 |
Hi Stan, do you place the jack under the side step bracket where it bolts to floor? |
3rd Sep 2022 4:57pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3074 |
If it’s just for a puncture then I’d open the door and use the normal jacking point as above.
3rd Sep 2022 5:13pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Or get in the car, turn the ignition on and within 5 secs press and hold the steps button in the overhead console for 5 seconds, the steps will deploy and stay there until you lock the car...
3rd Sep 2022 6:49pm |
Thank you for all of the comments, so from what you are saying it is possible to get a jack onto the jacking point with the steps deployed? I will try in the morning. I have got to get this tyre replaced! Kevin |
3rd Sep 2022 8:53pm |
Yes, I've used both a trolley jack and a sprinter in the original jacking points with steps deployed. The sprinter is easier but both possible with a little fiddling to get the angle to pump the handle. Mike - MPx
3rd Sep 2022 9:40pm |
Just make sure you have them locked out, they tend to have a mind of their own sometimes and the step retracting with the jack there would not be a good idea... Pete
4th Sep 2022 12:10pm |
Thanks for all the advice. Job done.
4th Sep 2022 4:26pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Easier than taking out the Allen key bolts would be simply to unplug the electrical connector at the front of the step once deployed… That way you can be 100% sure the step won’t try to move whilst your jacking/working on it 👍 |
4th Sep 2022 7:30pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 275 |
[/quote]Is there more than 4 screws or is the side step corroded to the brackets? If so any tips on re moving?
5th Sep 2022 9:46am |
Hi,
5th Sep 2022 10:55am |
Is there more than 4 screws or is the side step corroded to the brackets? If so any tips on re moving? Many thanks, Kevin[/quote] Hi Kevin, I understand it’s after the event; the steps are secured with 4 Allen screws each side. They corrode on to the brackets and can be pigs to remove. For future I suggest; 1.) mark the position of the steps before you remove them with a “ sharpie” pen on the underside as they can be tricky to realign. 2.) remove from the front toward the back; I used a rubber mallet to shift mine the first time. 3.) Use copper slip on the brackets and threads to help removal in the future The threaded fixing blocks on mine were badly corroded into the step due to dissimilar metals; I think they should move freely in the aluminium step body to make realignment easier when reassembling but mine were so baldly corroded that I couldn’t shift them; hence the alignment marks. All in all they are a pig to remove if they’ve been on for a while. Once off they are easy to do by hand subsequently but are fussy to realign. Bottom line is that I’d hate to be removing them in a lay-by on a dark rainy cold night to deal with a puncture! ( or worse still in an all lanes running motorway refuge )[/quote] I had a sneaky suspicion it was corrosion holding the step to the bracket. I will dig out my hide hammer later and give it wack! Many thanks again for all of the most helpful replies, I would have struggled with is if not for your help👍👍 Regards, Kevin |
5th Sep 2022 12:00pm |
