Home > Technical (L322) > Range Rover 2012 4.4. TDV8 Phutt after Engine Stop - Solved |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Number 1 sounds fairly normal to me. The fan can 'howl' sometimes on the 4.4 TDV8. It's warm at the moment and V8s get very hot very quickly.
2nd Sep 2022 2:13pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3141 |
The 'phutt' noise is fairly standard too I think. It happens on mine (as does the noisy fan as per GaryRR) but not an issue so far (am on 120,000 miles) |
2nd Sep 2022 3:53pm |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 |
Many thanks for the responses garRR and Dolphinboy.
2nd Sep 2022 4:53pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3205 |
I'd maybe get it checked out by a specialist for peace of mind 2012 TDV8 Vogue (L322) |
2nd Sep 2022 5:02pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Mine phuts too when shut off. I think it is normal with all the high pressure gubbins going on in the engine bay. Although I could be wrong and sitting on a time bomb, ahhhhhhhhh! Tom
2nd Sep 2022 5:19pm |
fmgl322 Member Since: 18 Apr 2022 Location: Koblenz Posts: 61 |
Yep, happily howling along here too. Just in slower traffic it would seem. Once I’m out on the open road though, there’s obviously enough fresh air getting through… only noise then is coming from the ancient tyres! |
2nd Sep 2022 5:20pm |
Mine has a hooting/moaning sound just above 1krpm as has been experienced by others but I wouldn't call it a 'howl' (maybe and Owl ). Not heard a phutt but in common with many diesels there is a throttle plate which closes to shut off then engine quickly on shut down (amongst other things) which will create a partial vacuum in the intake so it may cause a noise if you have a leaky seal somewhere? Are these noises are new is the big question you should be asking 2012 TDV8 Vogue (L322) |
2nd Sep 2022 5:28pm |
Hi fmgl322, that's exactly the same with mine. When cold runs quietly until it reaches operating temperature. Then in traffic and on hills the howling starts. I have watched the engine temperature on live data on the IID and that fluctuates between 97 and 101 Celsius. Not sure is that is hotter than the norm.
3rd Sep 2022 6:34am |
JayGee, thanks for the comment on the Phutt.... I have noticed that there is no Phutt if I let the engine idle for a while before switching the engine off...
3rd Sep 2022 6:50am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
Mine howls from cold if I pull away slowly in the village or town area, I was concerned at first but not now.
3rd Sep 2022 6:57am |
I spent the morning dismantling the hose that connects to the throttle body as I noticed yesterday that the side was covered in oily residue at the seem indicating that there was a leak there.
3rd Sep 2022 1:15pm |
Definitely worth a check on the connections on mine then. Tom
3rd Sep 2022 3:12pm |
This is a WELL KNOWN issue although I don't think it's the cause of any howling but is the cause of a potential problem later down the line with a DPF error. In my opinion, the pipe is poorly designed - both because the metal retaining clip gives holes for charged air to escape from and also because the seal isn't near substantial enough. The eventual failure is the double lipped green seal you refer to leaking air and eventually leads to a clogged or full DPF. The seal collapses causing the leak. See picture with highlighted areas:
I'm sorry to say that if your seal is partially collapsed, it can't be fixed and the seal also can't be bought separately anywhere (many members have tried). There's 2 solutions to it. 1 is to replace the part. It's not a big expenditure really (£170) and as you've found out, only takes 5 minutes to fit. The part number is LR022663. The second solution costs about 50p and is good for diagnosis/interim fix/periodic replacement. You need some gas specification PTFE tape wrapped around the throttle body in the location of the collapsed seal, to create a new seal (see picture below). I have done this on mine and now driven 3,000 miles without any further leaks. If you didn't clean the MAP sensor, also worth undoing the T20 screw and giving that a good clean up with electrical contact cleaner. Hope this helps. 2015 Range Rover Autobiography 4.4 SDV8 |
3rd Sep 2022 3:21pm |
Many thanks GaryRR,
4th Sep 2022 7:12am |
